Wheelhop?
#21
just to give you a hand, here are a few options.
http://www.brenspeed.com/tca019.html
are cheap and better then stock
http://www.brenspeed.com/tca027.html
considerably more expensive, but very stiff, however still poly ends on both sides
http://www.spohn.net/shop/2005-2008-...oly-Combo.html
are a street/strip option. Middle of the price range, more rigid then both, but a little harder to set up.
There are other companies as well, but those linked have proven to be reliable. If you end up going for a UCA, the CHE upper is very nice. I like that one better then most as the adjuster is much longer and easier to adjust on car then most.
#22
+ that JD the BMR's are a nice piece for N/A and cheap. What I have seen is folks installing spherical bearing ends and they spend 99% of the time on the street.
the spherical ends can be harsh great for the track. For the folks that have lowered the ride and have not made the 3 link componet swap Panhard adjustable UCA adjustable you U need to read up and listen up. The rear end is sprung up and the pinion is off and the factory bushings in the mentioned parts are on the way out!
TW
TW
#23
I chose my words carefully. Theres a bad stigma around the spericals. So long as you have poly on the body side and know how to properly set up your sperical side, you should not have any complaints. I run the combos with boxed subframe connectors, relocation brackets, and lowering spring. Mine makes no noise over stock
#24
I've about had it with my wheelhop... I've got about 200 squeaks and rattles now due to the constant hopping..
I won't lower the Stang... so I don't want to drop the LCAs.... So I need to either (1) up horse power significantly so wheelspeed is so great hop isn't an issue or (2) get another UCA... :P
#25
Hey robs, I see in your sig you have the J&M LCAs as well. I added them and they didn't seem to do jack for the wheel hop problem. I might try the GT500 LCAs or something. The J&M's added gear whine to the cabin as well. I have the relocation brackets with the J&M's and I still get wheelhop on occasion.
#26
An upshift that's harsh enough to chirp the tires (or worse) isn't too much different from a hard (but less than all-out hard) launch. There is some sudden rearward load transfer, the LCAs will see a shock load, and there will be a significant rear suspension anti-squat effect happening.
Norm
#27
#29
I thought the same thing and stuck the factory LCA back on... %^$# it was friggin 100 times WORSE!!!! So the J&M helps... but it's still there, there with a passion... but a LOT better than factory....
#30
BMR poly urathane/ spherical combo non adjustable LCA's will fix your problem. They sure the hell fixed mine. And im with JD if your spherical bearings are in correct they are quiet.
