Sponsored by:
Sponsored by:
Whipple Pulley change question
Old 05-25-2010, 09:30 PM
Witte 05
Witte 05's Avatar
Default Whipple Pulley change question
I'm going from the 4.00 pulley to the 3.875. Do I need any special puller tool to remove the 4.00 pulley?.. And then I torque the new pulley to 17ftlbs correct? Anyone done a Whipple pulley change please chime in with some knowledge...
Thanks!
Witte 05 is offline
Old 05-25-2010, 09:51 PM
BruceH
BruceH's Avatar
No special tool required. Loosen the 4 cap screws before taking the belt off.
I torque mine to 140 inch pounds which would be a little less than 12 ft lbs. IIRC the whipple manual calls out 125 inch pounds.
Once you do it a few times it only takes a few minutes.
BruceH is offline
Old 05-25-2010, 09:55 PM
hammeron
hammeron's Avatar
exactly and it gets easier every time.
hammeron is offline
Old 05-25-2010, 10:06 PM
Witte 05
Witte 05's Avatar
Thanks!
Witte 05 is offline
Old 05-26-2010, 12:05 AM
Diabolical!
Diabolical!'s Avatar
Unless you accidentally strip one of your four cap screws with a worn out allen bit and a broken torque wrench. D'oh!
Diabolical! is offline
GimpyHSHS
08-29-2015 06:30 PM
classic69FB
08-12-2015 11:58 PM
Soldier GT
08-12-2015 03:46 PM
ccwebb
08-11-2015 06:47 PM
Quick Reply: Whipple Pulley change question
