HELP........found a smokin deal on some 255/35/18, 255/40/18 but I am concerned they will look itty bitty on my un-lowered car. looking for info/pics of 18" rims with 35 & 40 tires.
Too small.
255/40-18 is enough smaller in diameter from 255/45-18 (which is an OE size on the 2008 GT500) to clearly notice. Load capacity is close enough to make up with a couple psi or so more inflation.
255/35-18 is so much smaller that it will look lost. And it has a load capacity better suited to my 2900 lb Mazda 626 than any S197 Mustang. All by itself, this part of the combination is bad enough that you should just pass on this deal.
Stick - it's not the wheel diameter that matters much here, it's how well the tire OD fills the wheel well. What you DON'T see in a huge wheel well makes it look empty, and the wheel/tire ends up looking kind of scrawny as a result.
Norm
I was thinking they were going to be too small also, guess I just needed advice from my fellow MFers. Thanks for all the input, the search goes on.
By the way, if anybody wants a deal on (2) 255/35/18 (new) & (2)255/40/18 (100 miles) Toyo Proxe T1R. Look at Craigslist Atlanta, guy in Douglasville has them for $450.00
