2011 GT Gear choices- opinions??
Standard 6-speed manual
Gear ratios
Gear ratios
1st 3.66
2nd 2.43
3rd 1.69
4th 1.32
5th 1.00
6th 0.65
Optional 6-speed automatic
Gear ratios
Gear ratios
1st 4.17
2nd 2.34
3rd 1.52
4th 1.14
5th 0.87
6th 0.69
3rd 1.52
4th 1.14
5th 0.87
6th 0.69
Source: http://media.ford.com/images/10031/2...g_GT_Specs.pdf
2005-2010 Manual
1st: 3.380:1
2nd: 2.000:1
3rd: 1.320:1
4th: 1.000:1
5th: 0.680:1 (think some come with 0.74:1 or 0.62:1)
Auto
3.22:1
2.29:1
1.54:1
1.00:1
0.71:1
even though 6th gear is only .65 vs. .5 in the T56 from the Viper/Vette I would STILL choose the final gear of 3.73
if 5th gear in the 05-09 cars is .69 and our cars didn't lose MPG with 3.73....why should the 2011 cars? They won't.
Wow, the 11.0/1 compression ratio and the aluminum piston combo in the new 2011's 5.0 engine is going to suck for boost. You would be lucky to exceed 6-7 lbs. of boost before you kill the stock engine, just like in the 05 and up Corvette.
O and dont worry 373 wont hurt your milage that much...It would be better than a full size pickup EASYYYYY. I could get 27 in the Bullitt on a hour trip or more and around town never below 20 unless I was being a JA.
are you referring to the 05-09 GT500?
if so, I think you fell off the turnip truck and hit your head. It may not be super impressive from the factory, but simple mods wake that motor up nicely. 600+ RWHP GT500's are quiet common now days.
As far as the gears go, your 6th gear is very similar to a 4.6's 5th gear. As shown above, you do not have a double overdrive. That being said, I have 4.10's in my car and regularly drive it on the freeway. It's not bad at all. I have never had one person comment about it in a negative manner. I have to assume its the old mentality thinking that 4.10's just wont' work for the street (freeway), but that's when people were running 4spd trannies. Anyway, before I ramble on any more, stay with the 3.73's, you'll be fine.
If you plan to drag race it, I would look at what size tire/wheel combo I planned to run and see what gearing would keep me in 4th gear at 7k rpm through the traps. I think that would probably be the 3.55s with a 27'' tire. Otherwise, screw it and go with the 3.73s.
