maybe a stupid question, but when you swapped the bulb, was it the same bulb that had the malfunction or the same side? if it was the same bulb but on the other side, its cearley a defect. if its the same side with the different bulb then its a wiring problem.
Not a waste.
AutoZoner for the needed load resistors....
True but.. I don't want to have to wire load resisters just to have a brighter turn signal or parking light. My time and money can go somewhere more relevant and worth while.
