Alot more noise after a short-throw installed
Is the MGW that much quieter then the other? How about the throws? I get stuck sometimes going to 3rd if I go in at an angle n Im hoping a shifter would help with that. They offered me the Roush at my local shop..
How could you not recognize the noise difference? It's not like it's a slight change.
The odd thing, though, was that I even called Roush support, and both guys there had no idea where any extra sound would come from, as if they'd never even heard of such a thing happening.
I did look at the MGW when I was shopping around. Ended up going with this one because I wanted to retain the stock shifter, and I don't like the way alot of short throws add extra length to the shift stick.
Don't know, but I wasn't fond of how it looked either. I went with the low/simple look.
Anyways, I ordered the Dynamat Xtreme speaker kit. Really hoping it takes the decibels down a few notches on the rollover noise.
I also wonder if a second layer would give twice the sound dampening. Anyone know?
You know... I was mulling over putting some onto the actual stick further down. So it's not just me, you can actually hear the noise difference when your hand is on the ****. Did you wrap it around or just stick a flat tab on somehow?
Was also thinking about combining your idea with putting another layer OVER the foam insulating pad (or just replacing the pad with the Dynamat) to further cut down noise.
Did the triangle-shaped pieces you cut interfere with the rubber shifter grommet being put back in?
The triangles folded under didn't compromise the dust boot or its ability to be installed. Since that stock sound deadening piece just sits there Im not so sure it would help to much in reducing sound if you put dynamat on it. the dynamat absorbs the vibrations, and that stock piece is more of a sounded barrier. Your issues are stemming from vibrations traveling through the car.
I stuck the tab in between the mating surfaces of the shifter itself and the shifter arm. I didn't want to wrap it around due to there being possible issues with getting the boot over that portion.
There may be some benefit in adding some tabs of the mat in between the lower rear attaching points (on the underside of the tranny tunnel) where the stiffer bushing resides. Not sure though.
