I HATE exhaust now :(
ya i should try the wd-40 attempt. It was so unreal. The very first bolt!. I was turning the right way, and i tried the vice grips, and those stripped it worse. I was like wtf. Clamped em on reallllllll tight got a breaker bar and cranked it and it just made it worse. It is almost like the fu*king things are welded to the bolt. Not to much corrosion on the setup.
I will try the wd-40 and the extractors... How do those work? it seems like they are normal sockets... what do the do to "extract" the bolt out. if all else fails i will be going to the body shop and getting them to remove them, It is ridiculous. This is the first real big problem i have run into with modifications that i couldn't figure out that day. All part of the fun huh
http://www.amazon.com/Irwin-Industri.../dp/B00008KISJ
Ive done all my exhaust work myself, and WD40 works miracles...
The extractors are made by a few companies, craftsman has them and theres a name brand called turbo socket. they arent regular hex sockets they have a "turbo" design that bits into the bolt usually able to remove bolts like 70% rounded
i didnt think that the wd-40 would make that huge of a difference.... i will have to try the "soaking method" on the bolts now. I guess if so many people had success with the wd 40 then i should to right haha....
o and as for the extractors i will have to use that on the stripped one. I now see how it works. How it actually bights into the bolt.
its the only thing keeping me sane. haha thinking that it is part of the huge adventure named mustang. I am going to go out and by a few cans of the stuff and just empty it on em
