Typical motor build costing??
My friend has been costing a replacement "built" motor for his GT and I've been steering him toward a prebuilt assembly such as the Aluminator which can be snapped up for around the $3k mark.
Assuming his motor hasn't grenaded and is a good runner, what would typical shop costs be to essentially swap out the short blocks including gaskets & sundry parts etc... Thanks Marcus :) |
bump....... I'm curious about this too.
the cost of the internals plus the labor of a shop doing the work will wind up about the same as buying a built short block. you are probly better off buying the short block. if you do the work yourself, getting the rotating assembly may save a few bucks. but if your not used to working on engines, i would get the aluminator.
Originally Posted by onederful100
(Post 7078571)
I already said the plan would be to buy the assembled short block and am questioning the additional cost of installation into the car |
Typically, on modern Ford cars, you're looking at about 20 hrs in labor for an engine swap (stock to stock)...
So depending on the labor rate where you live, it can fluctuate a lot. In FL, the dealer will charge you about $80 an hour. An independent shop will be around $55/60. So by the book, from $1200 to $1600 roughly... |
According to Ford's manuals its a 23-24 hour charge depending on auto vs. manual transmissions.
You can figure about $400 in gaskets and hardware on the low end. That's if you do the shopping. Retail will be significantly more.
An Aluminator short block such as the M-6009-A463V, would be a great replacement. Usually an OHC replacement will be between $700 - $1000 in labor if you leave the shop a few days to a week and have them take their time.
Originally Posted by SpartaPerformance
(Post 7079001)
Yeah, I wouldn't pay more than a Grand for the labor...
