anyone else with a crazy tight hood latch?
Old 06-28-2010, 04:56 PM
05xrunner
Default anyone else with a crazy tight hood latch?
So this has bugged me from the day i got my car..the hood latch is soo tight. I have to drop the hood from like half way up for it to close. I do not like pressing down on it do not want dents..its sooo tight is there a way to adjust this some or does it need a new spring. I feel like I am jumping from the top ropes closing it
05xrunner is offline
Old 06-28-2010, 05:33 PM
siggyfreud
siggyfreud's Avatar
Well you can adjust the rubber bump stops down a bit to make it easier to close.
siggyfreud is offline
Old 06-28-2010, 06:26 PM
05xrunner
i dont think the bumpstops really come into play..the amount of force it takes to get it past the latch is what slows it down so much that it wont close unless you really let it slam
Old 06-28-2010, 07:40 PM
GTVapor
I have the same issue on my 08 gt! It's a real PITA too!
GTVapor is offline
Old 06-28-2010, 08:13 PM
05xrunner
yea it sucks..I tried to adjust the rubber stops..I gave them like a 1turn down..it closed a tad bit easier not much but then the hood sat to low..so they cant be lowered anymore
Old 06-28-2010, 09:29 PM
Bird1606
Bird1606's Avatar
Subscribed. I have the exact same issue on mine, and with a Fiberglass hood, it's even more a PITA.
Bird1606 is offline
Old 06-28-2010, 09:54 PM
sas281gt
Pull off the rad cover, loosen the 3 or 4 bolts on the latch and move it up slightly and it should be good. Leave 2 of the bolts a little snug and tap the bottom of the latch up, with the 2 still snug it won't move too much. Tighten them down after adjustment and try it out. It it feel good tighten the other bolts back down. I won't take much horizontal movement to loosen it up.
sas281gt is offline
Old 06-28-2010, 09:56 PM
bym
bym's Avatar
yup same thing here,,, have to drop it from about 1 foot and a half, for it to close, sucks!
I dont want to imagine on a fiberglass one!
Im the kinda guy that likes to close the hood just by easilly pressing it down withthe hand.... ill check on the weekend to see it can be loosen up a little
bym is offline
Old 06-28-2010, 10:05 PM
NJ3
On my 06 I believe there were only two, but this is how I adjusted mine. I have my latch set a little high, less latch effort, because I had to install "ricer" hood pins on my Cervini's hood and I didn't feel I needed more latch effort.
NJ3 is offline
PaulH2
20
01-31-2016 09:48 AM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
mrtrodonet
09-29-2015 11:13 AM
Quick Reply: anyone else with a crazy tight hood latch?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
