Need help w/ OEM alarm system diagnostics. Can anyone help?
Before today - no problems. Had it at a dealer for 30K mile maintenance. Got it back and found the following.
1) My horn doesn't work at all now. Checked the fuse (#45 in the engine box), it is fine.
2) The key fob will lock the doors if pressed once, but when pressed twice doesn't seem to arm the alarm. (I pressed it twice, then opened the door from the inside, alarm didn't go off)
3) If I press the panic button on the key fob, the lights flash, but the horn does not go off (related to #1, I'm sure).
It seems I have two problems, horn and alarm which may or may not be related. Any ideas??? Thanks
bradleyb
11-27-2015 07:50 PM
breaking
10-02-2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
