Gauges, Gauges, Gauges!
Good setup?
http://www.summitracing.com/parts/ATM-3304/ $51
http://www.summitracing.com/parts/INN-3795/ $209
OR
http://www.summitracing.com/parts/AVM-30-4100/?rtype=10 $199
OR
WB A/F is a must with FI.
i also have a mechanical boost and electric FP. i like to keep an eye on the upgraded parts to make sure they are functioning properly.
although a good tune is important, that is one factor of the equation that amounts to the performance of your Mustang. your tune can be solid, but other factors can change that may set off how your car performs. gauges can alert you to a problem before it becomes a costly problem.
if you have money for a SC, it is a good idea to spend a few more $$$ to insure your costly investment doesnt blow up.
Next time you update your pics let's see that boost gauge pegged!
OP...As long as you go with a wideband A/F gauge you will be good to go. I have these.....
http://www.brenspeed.com/6178.html
http://www.brenspeed.com/6159.html
Oh, and don't forget the pillar mount....
http://www.brenspeed.com/05-08-musta...auge-pods.html
https://mustangforums.com/forum/2005...installed.html
heres a good write up. its pretty involved, but do-able.
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
