Unsafe tunes - why?
Well another common saying on the internet is that "boost doesn't kill motors." If you boost 10 psi instead of 5 psi, it is more stress on your motor regardless of the tune. Mechanical components do not have linear reliabilities. If you look in mechanical strength and material books, you will see that when you double the force on an object, the amount of cycles it lasts until failure decreases by much more than a factor of 2. The piston size is constant, and with cylinder pressure increasing drastically with the increase in boost, that is more force on your connecting rods, and more force equals much shorter engine lifespan regardless of whether the tune is safe.
No doubt that is true. However most people will tell you 10psi = safe on the stock motor. In fact most places that sell blower kits will tell you the same thing.
I still would like to hear what it is Whipple does that makes their stuff so much safer than everyone else's. Why. Why does their base tune not blow up motors. Ford and Whipple seem to have this figured out pretty good. What are they doing that is so special.
Driving style isn't it. People drive Whipple cars hard with the included tunes and don't esplode.
the whipple tune has a safe a/f ratio, and pushing high hp is not their main goal.
the base tune doesnt get impressive numbers, but its safe.
i believe Hammeron still runs the whipple tune for 4 years now.
like most i wanted more than the base tune and have a street tune, performance, and race tune for 100 octane.
the 2 lower tunes get me 413 rwhp and 449 rwhp, i have never tested the race tune yet.
both the street and performance tunes are around 11.5-11.7 a/f, but the whipple base tune has a safer a/f.
i dont push my Mustang hard that often, and its been running good for over 2 years on the stock block @ 7 psi with a Gen 1 whipple.
i am prepared to replace the block if and when it fails, but i want to prolong that for as long as possible.
My motor went at "only" 8 psi a few months ago... after that, I was always kinda leary about "safe" tunes, even though the tune I have is claimed to be extremely safe as well.
I chat on another site that has people in the 500+whp on the stock short block via Roush TVS R2300s.. crazy stuff.
Personally, my limit was 450whp down to 420 lulz
i mean i really havent seen threads about stock tunes for any of these kits blowing the motor either.
i've run it off and on.....on, when my hot rods are out, off when
they are back in. moose is one of the few who have always run
the whipple tune.
Riptide, it's all in the tune.....pick your tuner carefully.
For one thing, the A/F as stated above, on the Whipple is conservatively rich. The other thing is that the rev limiter is still in place on the whipple tune. Someone want to tell me what RPM they were at when their rods bent? MY bet is that it was usually north of 6300 if there wasn't an AF issue due to a bad tune or sensor.
