Sponsored by:
Sponsored by:
Yet, anpther HID question..this time OEM HID
Old 07-29-2010, 09:11 AM
TPony
TPony's Avatar
Default Yet, anpther HID question..this time OEM HID
Question: What do I need to install a set of used 2008 OEM HID headlights in my 2006? I read somewhere that this is not a direct plug and play, but that I needed a special harness or even have a different electrical set up. Tried searching specific question to no avail...what do the guru's say.. I know ...and I can't spell "another"...
TPony is offline
Old 07-29-2010, 10:05 AM
NOLA26
NOLA26's Avatar
As far as I know, you will need the lights, ballast, and wiring harness. Everything else should be the same. Same switch, just matters weather or not you have fogs.
NOLA26 is offline
Old 07-29-2010, 03:48 PM
BigDinTexas
BigDinTexas's Avatar
Is the housing the same as the non-HID headlights or is it a different P/N?
If different, what's the P/N's you have for them. thanks,
Don
BigDinTexas is offline
Old 07-29-2010, 06:40 PM
2005MustangGtGuy
2005MustangGtGuy's Avatar
To put the OEM HIDs on your car is direct plug and play, you just need the factory HID harness. There is no cutting/splicing involved. All you need are the headlights and the harness, the ballasts are built into the headlight housings. I put the factory HIDs in my car and it is fairly easy..
I bought my headlights from steeda and used this guide to install http://www.steeda.com/directions/162...steeda_hid.pdf
2005MustangGtGuy is offline
Old 07-29-2010, 07:12 PM
TPony
TPony's Avatar
quote=Is the housing the same as the non-HID headlights or is it a different P/N?
Don[/quote]
I have not purchased the lights yet...doing research up front. Another MF member is selling his OEM HID lights...again, just doing some homework, so I don't know the P/N.
TPony is offline
Old 07-29-2010, 07:14 PM
TPony
TPony's Avatar
Hmmm...that's what I thought...any clue on the P/N for the harness?
TPony is offline
Old 07-29-2010, 07:31 PM
2005MustangGtGuy
the part# on mine is 61A-3002-0677..I dont think its a valid ford part# though. You may have to call the parts dept. of your dealer and have them look it up..
Old 07-29-2010, 07:48 PM
TPony
TPony's Avatar
Thanks.
TPony is offline
5.0muscle
01-11-2016 01:17 PM
mungodrums
10-07-2015 04:01 AM
StalkerGT
09-25-2015 02:41 PM
Mobiusone stang
09-07-2015 08:46 PM
Quick Reply: Yet, anpther HID question..this time OEM HID
