2011 After market parts
Would it be safe to say that outside of the new 5.0 in the 2011 mustang, that most everything else is the same as the 2005-2010. Outside of the upper control arm and x-pipe. In other words mufflers,LCA,shocks,struts,etc
should interchange?
should interchange?
Their were some changes around the front Kmember or what ever they call it these days to stiffen the front end. Im told the old CHE Brace will not fit without modification, I dont think other changes like extra sheetmetal in the factory "frame rails" or what ever you want to call them are going to affect fit of anything.
LCA, Shocks and Struts should still fit.
The non-Brembo 5.0 front springs are softer with larger sway bar than the 2010 Track Pack. This was to get similar handling with better ride.
No one seems to really know on the Brembo springs other than the different part number.
I think the 5.0 is actually 10 lb heavier at 430 lb. The weight I have from the 2005 press info is 420 lb for the 3V. The block is lighter. The heads and cams are not.
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
