Front tires or rear tires wear faster?
Sounds like for whatever camber you've got, either the toe is wrong, you aren't cornering hard enough often enough, or you need to find another front tire inflation pressure. Maybe some of of each.
Rear tire wear - and handling and ride comfort - seems to benefit from having them inflated slightly less than the fronts
(by about 3 - 5 psi). But let them get too low (or run them too high) and you can trash a set of rear tires pretty quickly.
Norm
Norm
10-05-2015 06:07 PM
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
