What are the correct tire pressures?
Excellent info guys, thanks Norm. The only reason I'm posting at that crackhead hour of the night is because my 2 month old has no concept of time???
20x8.5 - 35mm
20x10 - 38mm
I drive 80mph most of the time and go around corners fast.
PS. I just had this staggered setup installed and I'm not sure what the pressure is now, but it looks like 1/2 inch on either side of the rear tire is not touching the road, even under hard cornering???
20x8.5 - 35mm
20x10 - 38mm
Your rear tire pressure may be a little high - a load index 101 or 102 tire does not need as much air as a 97 load index tire in order to safely support the same corner weight. There is a rough correlation between differences in load index and differences in pressure for the same load rating, but I don't have it handy.
If this picture link works, maybe we can narrow things down a bit.
http://www.amazon.com/gp/product/B00...F5SFJ0GM0ZPDBZ
I will get those section views up, it's just that the only way I can do it is a little clunky and I have to delete a couple of other pictures first.
Norm
Here they are. I'm not even going to try to get the shape of the shoulder areas any closer. Not worth it for the usual comparisons.
I used Falken's dimensions for the 20's instead of converting mm to inches. Comparison in both cases is to the OE 235/50-18 on 18 x 8.5.
There's only about 3" between the rim flanges and the ground, and that's with the tire unloaded. Figure you lose a half an inch or a bit more due to tire compression when you drop the car down off of the jacks. The couple of psi extra stiffens the tire, so you don't lose as much and the tire is stiffer and won't compress as easily (which you will feel).
Front . . . has a little more sidewall bulge shape
and the rear
Norm
and the rear
Norm
ccdguy
09-19-2015 05:20 PM
09-08-2015 11:50 AM
