just dynoed! Need your help!
Hey whatsup everyone. Had my car just dynoed by greg at RET.
I have my graph and posted it up down below. Now, im running all bolt ons with PRE PROGRAMMED SCT X3 tunes
87 OCTANE
K&N intake
Steeda Delete plates
JBA shorty headers
Magna high flow x pipe
Magna Cat
UDP
Alum DS
Now by the graph, on the first run its running quite lean, obviously attributed to the canned tune. So we go in and adjust WOT A/F to 8% richer.
Now the second run which is shown the graph, yields more power but still its running lean.
Give me your thoughts on it and what i can do.
1) I want to stay 87 octane
2) Would maximizing WOT a/f (14% Richer) be enough. 8% richer lowered a/f by one point. would another 8% increase lower it another 1 point? Would any other parameter in SCT x3 be able to adjust this issue?
3) is getting an email tune the best option for me? I want to go the least costly route and stay within the parameters of the pre progammed sct ideally.
87 OCTANE
K&N intake
JBA shorty headers
Magna Cat
UDP
Alum DS
I can't speak intelligently on the A/F but your RWHP numbers look decent for your mods, maybe just a TAD low but not by much.
My personal feelings about the canned vs custom tunes, even the 87, is that the custom tune should add at least 3-5 RWHP over the canned.
Tailpipe sniffers generally indicate about .5 leaner than actual af. With that said think about how much you have into your car vs what a different tune will cost. At least get an email tune. A better option would be a dyno tune. I'd forget about running the sct canned tune.
I want to stay 87 for that reason, i dont want to pay 20 cents more per gallon every time i fill up. it is a dd so i drive alot. Which means im not at WOT all the time. It may sound stupid but it is what it is. I feel its not worth the 5hp more. I want to maximize the power in 87.
I cant rewrite custom tunes since i dont have a custom tune to begin with. I am only using the sct handheld parameters.
As of this point i increased WOT a/f to 12% richer. On another note, Is it better to be richer than lean. Will i lose power the richer i go? But will be safer right?
Look at your red af line. It started to go super lean before 6k. I'm going to guess the dyno operator told you to shut it down at that point. You really need a custom tune. At the very least go back to the sct without adjustments because at least the af stayed flat at wot. $50-$75 will get you a pretty good mail order tune. A dyno tune shouldn't cost more that $150 and you will get your dyno pulls included in that.
Rule of thumb is leaner will make more power until the motor seizes. Richer runs cooler with less power until you wash down the cylinder walls and the motor seizes. See the trend? Your best bet is to get a tune and imo you are playing with fire making adjustments without a wideband or dyno.
Yes, you have to get a dyno tune to get the most of your mods, you dont want to run lean or rich, Your complaining about 20 cents a gallon more, and yet your dumping raw fuel out and not burning it, makes no sence to me....
My Brenspeed 89 tune is much better suited for me than the 93 tune.
AMEN!!!!
