MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   2005-2014 Mustangs (https://mustangforums.com/forum/2005-2014-mustangs-43/)
-   -   car won't start (https://mustangforums.com/forum/2005-2014-mustangs/614591-car-wont-start.html)
Roush06GA Aug 25, 2010 07:18 PM
car won't start
I havent driven the car in ab a month. it has been just sitting in the garage. i has quarter tank of fuel and the battery is good. when i turn the key it makes a screaching noise. any ideas. i know its hard to describe without a video or standing next to it. thanks
evilspock Aug 25, 2010 07:23 PM
Bad Starter?
Roush06GA Aug 25, 2010 07:35 PM
the sound its making is also like a clicking coming from the hood.. i really dont know what bad starter sounds like.
Adam Aug 25, 2010 07:44 PM
Whenever I've heard clicking it has been a bad battery. Use a multimeter to check the battery voltage. If your voltage is above ~12.4 then it's probably your starter.
Menace Aug 25, 2010 11:22 PM
Having encountered this problem as well, I was worried about it being the starter, and alternator because of the symptoms... but in the end it was just the battery. 5 year old battery, having sat in florida sun for nearly a year with no one really starting it... Result, dead battery.
Of course, check yours out and make sure before you go spending any money... but that's where I would look first.
Analyzer52 Aug 25, 2010 11:42 PM
Most likely the battery test the battery or jump it, it will probably start right up. This cars have a lot of drain put on the battery when the car is parked awhile.
shad2009 Aug 26, 2010 06:10 AM
I would guess it's the battery also...when i went to test drive a black gt, i went to go start it, and it made that same noise that u r describing...it too just sat in the lot
Nuke Aug 26, 2010 07:55 AM
There are TSB's and numerous threads regarding bad batteries/alternators. The 05's and 06's are notorious for high parasitic current draw due to numerous accessories, particularily the Shaker systems. Have the battery load tested as well as having the alternator checked out. Hopefully, it's just the battery.
jknowlton Aug 26, 2010 09:41 AM
clicking usually means battery, so def. check the voltage. I good battery is 12.7volts, but anything about 12.4 SHOULD start but still has drained down and might not start it.
12.7 100%
12.6 75%
12.3 50%
12.0 25%
11.8 0%
2005Redfire6 Aug 26, 2010 11:32 AM
12.7 100%
12.6 75%
12.3 50%
12.0 25%
11.8 0%
+1, the 3 times my battery have died for leaving my fogs on the starter has clicked. Also I've let my car sit for about 3 weeks and the battery died because of the alarm.
© 2026 MH Sub I, LLC dba Internet Brands
