Cleaning drain/filter under hood to prevent leaks
#21
Seems all cars have these now. My 2002 Xterra had one and was the first vehicle I ever owned that did.
#22
Time Out!!! I am the OP. Just FYI:
This thread was not intened to be about the cabin air filter (pro/con)- only if it needed to be removed to get to and unclog the grommet/drain that collects leaves/debris and may cause water leaks through the cabin air filter on our cars.
I am also interested in the comments about:
1. getting to this area without removing anything and
2, the potentially harmful leak from the stock exhaust? Is this correctable with an aftermarket exhaust?
Thanks to all.
Thanks to all.
#23
I simply cut off the bottom of mine so they are open all the way and allow debris to flow through..really a stupid idea to have the bottom pinched shut to catch crap and plug up. You dont need to remove anything to get to them...you can see and feel them from the engine compartment.
How do you get to them without removing anything??? Details or Pics would be GREAT!!! Thank you - this would be a tremendous help.
#24
I think they look more like pouches than grommets. Look at the battery. Then move your eyes along the firewall a few inches. You should see what looks to me like a black pouch. At first, you might think it is closed at the bottom, but there is a slit there. Squeeze the pouch to get the slit to open and feel around to see if there is debris lodged there. Once you have found the passenger's side pouch, you should be able to find the one on the driver's side. It is about the same distance from the end of the left side of the firewall as the passenger's side pouch is from the end of the right side of the firewall.
#25
now once you find them as well described by Art161...just pull them out and cut off the bottom and pop them back in...it will be clear to you when you pull one out..
#26
These things are so easy to access with the hood open. Just pull them out. clean them out, stick them back in their holes then pull lightly to seat them. You have to open your hood to check fluids or change them just make them part of your service routine and you will have no problems. If there is large amounts of leaves turn wipers on then key off when they are vertical. A small phillips screwdriver will back out the center pin of the two snap fasteners and the passenger side cowl cover will lift up to reveal the plenum and cabin filter. Scoop out or suck out debris and reinstall as removed being careful to engage all ten tabs into their slots and sealing to the windshield. replace push pin fasteners. Don't make this a big deal its to simple. Catch you later, Bob.
#27
He guys,
first time i cleaned my grommets after importing the car from the states was really funny.
I removed the passenger side grommet and pull out some "parts". These parts are little bones from an ohio mouse
It depends where you live. Here are a lot of small leaves in the autumn. I have to clean.
Greetings, Mario
Greetings, Mario
TfcCDR
09-14-2015 12:08 PM
