stupid question, are trannys interchangeable...?
do you think it is worth it? how much $ will i be in on it
I can't recall anyone doing this swap with the GT Tremec on the sixxers, I believe it'd be tough to find write ups about it.
Some folks have successfully done a 6spd swap but that ain't cheap.
You could always find a T5 that will bolt right on for cheap in a bone yard and still use your buddy's pedals, and hydraulics etc... but it's a primitive and clumsy transmission. The Tremec on the GT feels so much better...
This project is a lot of headache for the non pro, so beware.
Have no idea really, some engineering has to done in regards with pilot bearing as well since the input shafts are different etc...
It's ok though... the VIN on his GT will say it's supposed to be a manual... so hopefully someone spots that little piece. Why is that bad? I'm pretty sure the transmissions for the GT's are better in either auto or manual, so why would I wish a fellow enthusiast to get ripped off?
Plus i dont think there is any reason to get all worked up because i think i will find a v6 manual so i dont have to do all the plates and retro fitting
Sounds like a good idea but thats dumb at the same time, why would he take your parisitic automatic and put it in his GT? I'm pretty sure they're two different automatics between the GT and V6. Fail.
