Windows won't go up or down from the switches.
Windows won’t go up or down from switches
2005 Mustang windows will do short drop. Neither window will roll down, from either switch. Radio will also not power. All fuses have been checked, relay under kick box has been replaced. Switch has been replaced. Does anyone have any suggestions? Trying to avoid dealers fee’s. Thank you!!
The first thing you should try is the relearn procedure for the windows.
As I recall the steps are to start the car, roll the window down but hold the switch for 5 seconds, then roll the window up and hold the switch for 5 seconds. That should recalibrate the window and the drop.
When i open or close the doors the windows will go up and down like normal. The switch on both sides doesn t work, neither the backvieuw camera in my mirror is not working anymore. i allready checked all the fuses and nothing is wrong. So i don t know what to do anymore.
Check the smart junction box (behind the kick panel, passenger side) and see if you have any water damage there. The cowl drains can get plugged on the S197 and that causes lots of issues with electrical things.
I can understand that.
If it was just the switch on the door then I would focus there -but with the back up camera involved as well I'm not sure what else to suggest. Maybe someone else has some ideas. Might be worth checking the wiring to the switches and eliminate that as an issue. The back up camera may be unrelated.
