My 2011 Mustang shimmy saga beginning to today
#21
I think anything loose would manifest itself at speeds other than 80+, I am leaning heavily towards an issue with the EPAS similar to the GT-500 EPAS TSB.
#22
I doubt it. My car does it just like yours and mine doesn't have that new EPAS. Many others on that other thread are suffering from this as well. I think you're barking up the wrong tree. I still think it's an aerodynamic anomaly on some cars, suspension problem or drive shaft issue.
#24
Also, since when was "smooth as eggs" an analogy xD
#25
I feel like it's clearly not tire balancing based on what he's saying....the fact that he had them rebalanced what, 4 times? says that it's VERY unlikely that every one of those shops did it wrong and gave him messed up unbalanced wheels.
Today 90mph was smooth as silk, but I bet the ride home will not be.
#27
#28
have you checked the brakes? I was reading on a honda forum and person had shaking problem that was caused by pressure from the rear brakes not releasing fully and leaving the front calipers slightly closed on the rotors causing the rotors to warp a little making the wheel shake at all times. probably a long shot but might be worth a try to have the rotors checked to see if they are warped.
#30
Argetni, yours and my car are doing the EXACT same thing. Mine is a '10 without the new PS system. I'm telling you they are identical problems. One day mine shakes and the next it's perfectly fine. It's been great for the past 3 days and then BAM out of the blue it will start to suck. New pavement for me is also the worst. I feel every groove in a freshly paved road.
