Sponsored by:
Sponsored by:
X-Charger Installed, minor problem
Old 09-23-2010, 03:23 PM
killdar
killdar's Avatar
sounds like its not in right, they do make tools to rethread the hole if its badly crossthreaded, u gotta be made careful w/ it tho since it won't be good as new
killdar is offline
Old 09-23-2010, 03:34 PM
carguygt
carguygt's Avatar
whats an x charger? Ive never heard of it...is if a V6 only supercharger or somthing? Not trying to sound nieve or stupid...
carguygt is offline
Old 09-23-2010, 04:00 PM
highline
highline's Avatar
Originally Posted by dmhines
I traded the car in so it's no longer my problem.
Any my wife thinks a 25K miles used car is ok to buy.
highline is offline
Old 09-23-2010, 04:02 PM
AlloySixxer
AlloySixxer's Avatar
Ok, yes I've tried to take the plug out and it comes out fine, it's just hard to get back in. I'm going to let Injected worry about that next Friday when I take it in. I triple-checked all the plug wires with Dave on the phone and everything was alright. He thinks it may be a vacuum leak, because I couldn't reuse the stock PCV tube, so I had to fab something up which isn't the proper quality. I'm going to O' Reilly to pick up some PCV hose and we'll see how that goes.
Yes, the X-Charger is a V6 supercharger.
AlloySixxer is offline
Old 09-23-2010, 04:09 PM
JDWalton
JDWalton's Avatar
just buy the right sized tap pack it with a ton of grease, run it like 1/8 of the way down the threads, back it out, clean off the used grease, apply new stuff, rinse and repeat till you are threaded the distance you need that spark plug to go in. Do it right this time and never worry about the stupid thing again.
JDWalton is offline
Old 09-23-2010, 04:12 PM
highline
highline's Avatar
alloy, i'd go with your thoughts...take it in and let Injected handle it Friday...I'd probably tell them the situation though
highline is offline
Old 09-23-2010, 04:47 PM
2005Redfire6
2005Redfire6's Avatar
Thumbs up
Did you take out a loan to take it to injected?
2005Redfire6 is offline
Old 09-23-2010, 07:37 PM
Moderator
JimC's Avatar
The Xcharger is a "roots type" supercharger made by Explorer Express (www.explorerexpress.com) for the 4.0L V6.
Here is a recent picture of mine after painting it to match my car and installing the Xtreme kit (an intercooler)
And this is how it looked as first installed
JimC is offline
Old 09-23-2010, 08:05 PM
tigercrazy718
tigercrazy718's Avatar
jim did u post those pix up anywere else? bc that looks super bad *** lol
tigercrazy718 is offline
Old 09-23-2010, 09:14 PM
afixer
afixer's Avatar
alloy did you install the rear plugs in the rear of the manifold? i am assuming you have the new style discharge manifold.
just rear of the supercharger are 2 1/8 inch pipe holes that get plugs in them.
also what is the angle of the plug at when it is in. does it look like the others?
many guys have had small leaks due to lack of proper tightening. did you tighten them in order then re tighten them - the manifold bolts i mean. take some carb cleaner and spray around you should hear the sound change if you find a leak. on the collective we actually have a explorer express section. i moved your thread on the collective to it. when you get to your thread over there just back up one and you will see lots of info on other installs and advice from some of the over 160 kits out there.
between the guys here and over there your get it all sorted out.
afixer is offline
Quick Reply: X-Charger Installed, minor problem
