i has a problem with the 3.7L Motor
I have a problem with the 3.7L Motor
We purchased a 2011 Mustang with the 3.7L V-6 in June. In August, we started noticing a tapping sound under the driver's side cam cover. Sound got progressively worse so we took it to the dealer this Monday. Upon removing the cam cover, the technician noted visual damage to two of the followers. Data was reported to Ford. Just got off the phone with the Ford dealer. Ford now says they are aware of a problem with the 3.7L V-6 with regards to early failure of the followers. They have no solution and they have instructed the dealership to put the (damaged) engine back together and give the car back to us until they figure out a fix. Thanks for nothing Ford! I guess they didn't have enough money to do real testing and their business model is that the Ford customer will do their durability testing for them. Meanwhile we're stuck with a brand new car (~6K miles) that has a bum engine. Ford just lost a customer forever.
First I heard of it. But kinda sucks that they just say here keep driving it until we figure out a solution... I would be mad too.
That has lemon law written all over it. If you have documentation proving that the company has no solution right now and literally told them to put the damaged engine back together and send you on your way. You should be able to lemon law that car.
In a bit of a related matter, I scanned some reliability data this morning that seems to indicate a rather disturbing trend for the 2011 Stangs. I'll try to post the link.
so they said they didn't currently have a solution but would notify you when they did? What more do you want them to do?
If you think any car or engine platform launches perfectly, you are a bit naive. If they don't fix it in a reasonable amount of time, try to get it lemon lawed. Ford might even offer to buy it back from you to use it to find a solution to the issue, this is a common practice.
The first generation Audi/VW 2.0T motors seem to have a very similar issue as well but the failure seems to happen right around the time your warranty would go out. I'd protest the dealership to replace the follower as a fix till something premanent comes along. Sorry you're having to deal with this.
To imply to a customer "Here's your unrepaired car back. We'll get back to you." is irresponsible and near-criminal. A responsible company would make some type of repair or put you in a loaner; not send you on your way with a new car that's been diagnosed as unreliable and on the verge of engine failure.
Sorry to hear about the car..Wow problems with the 3.7, I've read several posts about 5.0 problems, sounds like Ford should have done more testing on these cars.
