HELP BEFORE I END UP AT THE DEALER
I am still having a problem that keeps re-occurring with my power steering. I thought it was the kink in the hose from the fill tank, but it just started up again last night. What happens, is it gets EXTREMELYYYYYY tight when I try to turn the wheel left, but is fine when I turn it right. Anybody have any ideas???
Sorry, not much help here. I am not familiar with steering setup on the 2010s. Didn't they go electric? If not, sounds like something bad in the steering box. Why are you afraid to go to the dealer? You should have plenty left on the warranty.
I am not sure on the set up either, and I am not afraid I just hate to bring my car there cause its my DD and I end up going the day sometimes 2 without a car. I brought it to the dealer a month ago to fix my ambient lighting and they never fully fixed it, just reset the battery.
Call ahead and schedule an appointment. Ask for a loaner when you schedule the appointment and you should be good to go. As far as the steering, the 2010 still used a hydraulic steering pump; 2011 switched to the EPAS. For your issue, it sounds like your rack is bad. I remember a very, very long time ago my brother had a 1980 Mustang that had that problem. Had the power steering pump checked and serviced many times to no affect. If I recall, it turned out the steering rack was bad.
You should ALWAYS be able to get a loaner. Make it cleear that not only will they NOT get you back for service, you'll be sure to find a more "customer-friendly" dealership and service department.
With that said, don't even TRY to diagnose it or repair it yourself. That's what warranty is for.
