View Poll Results: Should I blackout the front?
Yes do it!
43
79.63%
No...don't.
20.37%
Voters: 54. You may not vote on this poll
To blackout or not to blackout?
#21
Laws against HID should be repealed, and if any law maker in the future dares to enter a bill to ban them again, it should be written in the laws that said lawmaker should be instantly dragged out, tarred and feathered, hung up by his toes, flogged with a rubber hose, and then drawn and quartered by chickens!
Seriously, laws banning HIDs are unreasonable. They can be adjusted so that they do not blind oncoming drivers like these unreasonable lawmakers think they do.
#23
In all honesty, I know it's OT, but I do have to say some HID's are honestly hazardous to drivers. I know they can be made so that they don't mess with other drivers but there should be something in place to enforce that, since a number of times i've had drivers coming at me with what seemed like high beams and when i flashed my lights at them and they flashed back even BRIGHTER, thats a problem that they seem as blinding as highs.
#26
I suspect that the lawmakers have not been able to come to any consensus on where to draw the line. Attempting to legislate things like "consideration for others" and "common sense" are exercises in futility, so I'm not too surprised that they dropped back to an easily definable "either-or" point on the cautious side.
I know the appearance-is-king/my-car-has-to-have-a-certain-look folks are not going to want to hear this, but the higher the color temperature and the "blue-er" they look, the more the light gets scattered (meaning that more glare is produced for a given lamp output). Think about it - a glare-blinded driver is not really what you want to have aiming his car at you (eyes tend to follow unusual light, hands follow eyes, car follows hands . . .). And as more of the light gets scattered, less of it reflects back toward the driver of the car with those bulbs and is actually useful to him.
I had my car built with the OE HIDs, and they've always had a dark patch, maybe 75 - 100 feet out on the driver side that I'd always found annoying. I finally got around to cranking on the headlight aims a little (less than one full turn each) this past weekend. Moved the dark patch out and probably up a little (though pretty much by definition, a dark patch shouldn't be "glare-y"). Time will tell if it's too much for oncoming traffic, but having only been "flashed" once in over two years for running the low HIDs plus the fogs (to fill in that dark patch) I'm not expecting trouble. But I will post back if I do get some early "negative feedback".
Jim - it probably would have been more productive if the powers that be in CA or out your way had put more time into this issue and less into, say, the CA requirement for service facilities to check your tire pressures and adjust them if they're more than 1 psi low (that one went into effect this past September).
Norm
#30
Totally do it! Have you seen my car? I've blacked out all my lights and I have no issues what so ever with visablity. I also have HID headlights. If you want a suggestion I would check out "Xpel" its the kit I used for my headlights, fogs, and front turn sig's. The kid is outstanding and will protect your headlights from a rock hitting them a 100mph. The kit is call a "headlight protection cover". It goes on like tint film but is 40mil thick hard plastic the you can heat up to mold to your fogs and turn sig's.
