Engine & All Electrical Systems Failing
I'm skeptical about the alternator being the problem. My reason: if the battery is healthy enough to re-start the car when everything craps out, then it should be healthy enough to handle keeping the engine running when the alternator rolls over and plays dead. The battery and alternator are connected in parallel to ALL of the cars' electrical load. You should be able to lift a lead to one or the other with the car running and the car should never skip a beat.
I took the car to Advance Auto Parts to have the battery and alternator tested, and even the manager there said that he didn't think it would be a battery/alternator issue because the battery seems to hold a charge enough to restart the car whenever the engine cuts out.
I'm not ruling out electrical completely, but I'm kind of at a loss right now. I have heard that a bad ECU can cause problems like this, though... anyone think that's a possibility?
Talked to the tech guy at the dealership, he said its probably not the fuel pump because when those go bad, they just die... meaning that the car wouldn't run fine sometimes and then act up, it just wouldn't run.
He actually said that there's potential that it could be the throttle body malfunctioning... he said that happens occasionally and could cause the engine to cut out due to starvation of oxygen...
I dont know what the error code is because I reload my tune as soon as I can after each incident because the car feels sluggish until I do. I am going to leave the C/E light on next time and take it in to have the dealer check the code I guess...
KEM Motorworks
08-14-2015 10:13 PM
