See I think the problem here is that the input shaft was inserted before it was properly lubricated, this causes low dyno numbers and unsatisfying results.
I think maybe the shaft on the dyno has a bad curve in it possibly. They should give it a shot to fix it. May need some more lubrication on the dyno bearings.
Bad curve in it the dyno shaft? Throwing more lube into it will do absolutely nothing. That dyno needs to be shut down and have the shaft completely replaced. A shaft should never be curved, bent, crooked or whatever.
Ahahahahahhah! Between the sex jokes and the pathetic dyno, this thread is very entertaining. You'd better get your money back for that; their dyno flat out fails.
