Just installed my Brenspeed tune and HOLY #$%^!!!
I felt the same way about about three years ago when i got my first combo. Wow did it wake the car up. Now iim around 15k down the road including a saleen install coming wednesday. On yea. I'll get to say holly cow again
Personally I'd say yeah, an 87 tune would be best for daily driving, since as the tunes get more aggressive it becomes easier to spin your tires accidentally and I'm assuming that's something you wouldn't want. I'm running an 87 for my daily drive
Yes. There's actually a bigger "kick" going from the stock 87 tune to a custom 87 tune then the amount of "kick" going from a custom 87 tune to a custom 93 tune. But I'd recommend loading your lowest octane tune (you typically get 3 tunes) first and drive it like you stole it, then repeat that drive with the next higher octane tune and so forth. You'll be surprised how each tune has different characteristics at different RPM's. You may decide on the 89 like I did for 99% of your driving.
Now if you have a lower octane tune, you can use higher octane gas but is virtually a waste of money.
What kind of repairs would be needed if that were to happen? Would it be big $?
Potentially... Essentially what happens is the higher octane tunes gets the spark slightly earlier because it takes a little bit longer for the flame to propagate and really build up pressure the cylinder. So if you use a lower octane fuel which burns faster you'll have pressure build up before the piston is at the top of the stroke which puts ridiculous amounts of stress on the lower end. Depending on how severe it is, it can be rather inconsequential or it may result in catastrophic failure. Not something you'd want to play around with for sure.
