My baby is throwing codes!!!!!!
Hey guys, need help here. I was driving down the freeway the other day, at about 75 mph, and all of a sudden it seemed like my engine shut off. I hit the gas and got nothing, so I down shifting and hit the gas and the car lagged, didn't really take off as it normally does. Did that a couple of times and it finally responed, as I exited the freeway it did the same thing. And as I came to a stop, it started to idle rough, and 1st gear did get too much response. I checked the codes, and P0171 and P0174 came up. I looked it up, and it reads, P0171 - System Too Lean (Bank 1). So I cleaned my MAF sensor, and put in a new fuel filter. Its still doing it though. I'm thinking of taking into the dealer and have them trouble shoot it, and I will go from there. Any help would be appreciated. And I also put some Techron in my tank, in case it was that. Thanks guys.
Possible causes:
• Fuel system:
* Damaged or leaking fuel pulse damper
* Fuel filter plugged or dirty
* Damaged or worn fuel pump
* Leaking fuel pump check valve
* Leaking/contaminated fuel injectors
* Low fuel pressure or running out of fuel
* EVAP canister purge valve is leaking when canister is clean
* Fuel supply line is restricted
* Fuel rail pressure sensor bias
If you have a 05-06 there is a TSB on fuel pumps.
• Air induction system:
* Air leaks after MAF sensor
* Vacuum leaks
* PCV system leaking or valve stuck open
* Improperly seated oil dip stick
* Damaged MAF sensor
• Exhaust system
* Leak in manifold gasket or mating surface before or near HO2 or EGR
* Vacuum hose disconnected on EGR system module applications
* EGR valve/tube gasket leak
* EVR solenoid vacuum leak
* Damaged secondary air injection system or Mechanically stuck valve
Some of these causes may not apply to specific applications
• Fuel system:
* Vacuum leaks
• Exhaust system
