05-09 S197 trunk bulb size
I assume you mean the high mount stop light bulb. It's a 921. I installed the Sylvania SilverStar 921ST in the g/f's Pony to offset the "MUSTANG" decal. The 921ST is advertised as 30% brighter than standard 921's.
I'm at work and the Stang is home. Did you check the OM? Did you pull the bulb and get the # off of it? I'd suspect the bulb for the '10 is the same as that for the '05-'09s.
Nuke, if you could check, that would be great!
mykim72--I couldn't find it in the Owner's Guide, on the Sylvania website, on the AutoZone website, or on the O'Reilly's website.
I Googled and found a reference to 212-2, also called D4MY-13446-A FORD, but it is not entirely clear to me what year(s) that covers.
This is a bear!!!
This is a bear!!!
movielover40
09-15-2015 10:37 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
