First clay bar experience WITH PICS
#71
I am pretty sure Ultimate compound is a heavier cut then the wolfgang..if you used teh tangerine pad with teh Ultimate compound that would probably even be enough to clean it up and finish down nicely..but i say tape a small area..use the SwirlX and the tangerine to see if that removes all the marks..if it does do car with that..if didnt get all try teh UC with the tangerine pad and see if it works and finish down without any hazeing in the paint..if it hazes up some..follow up with the red pad and Swirl X..but i would only try the Cyan and UC as if nothing else works because that combo will have ALOT of cut..remember always try and use least aggressive combo as needed to get job done. be sure to order 3 of those towels to..cause if you have sub par microfibers..you will just put swirls and spiderweb marks all back in paint you just buffed
#74
Its about a 1% chance of doing ANY damage to paint with a porter cable Dual action. Even with the heaviest cutting pad and some M105 it would take sitting in one spot for 5min to probably cause any..Please dont try and make it sound like its hard to do and scare others because its not hard at all and there is maybe a 5min learning curve on that PC before you are good to go with it
#75
The main tip here is don't use a rotary tool on a car unless you know what you're doing, because that will QUICKLY eat through your paint.
