Sponsored by:
Sponsored by:
07 Mustang GT: Alternator pulley squeaks..
Old 01-03-2011, 01:02 AM
e.rod87
e.rod87's Avatar
Default 07 Mustang GT: Alternator pulley squeaks..
So just recently my mustang has been squeaking under the hood. It has become notoriously louder, especially now since the days have been very wet and rainy. I sprayed the pulleys with WD40 and it silences it, and from that I realized that the squeaking came from the alternator pulley.
The WD40 is only a temp fix as the squeaking returns after I clock out and head home (4 hrs later). What can I do to fix this? Thank you.
e.rod87 is offline
Old 01-30-2011, 01:34 AM
TPony
TPony's Avatar
Guess no one answered this one. I had the same problem with my 1999 Ford Ranger where I replaced the serpentine belt and fixed the problem. However, something you would have to replace the pulley tenjsioner too.
TPony is offline
Old 01-30-2011, 01:58 AM
Recon111
Recon111's Avatar
The Belt
Recon111 is offline
Old 01-30-2011, 06:18 AM
Nuke
Nuke's Avatar
Sometimes it's just the belt. Other times it's the belt caused by an out of alignment pulley causing belt wear. By virtue of the squeak going away from lubing the belt (providing no generous overspray), you've eliminated the possibility that it's a noisey bearing.
A still-short but longer term fix is a belt dressing which might last weeks or days instead of hours. Otherwise, sounds like a trip to the shop.
Nuke is offline
Old 01-30-2011, 10:16 AM
2005Redfire6
2005Redfire6's Avatar
Mine squeaked after I replaced my belt tensioner, I think its a belt.
2005Redfire6 is offline
Old 01-30-2011, 01:06 PM
e.rod87
e.rod87's Avatar
You guys kick ***. Thank you for the leads.
e.rod87 is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
Soldier GT
12
08-20-2015 09:42 AM
jjwinel78
08-17-2015 03:34 PM
Soldier GT
08-12-2015 03:46 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 07 Mustang GT: Alternator pulley squeaks..
