Gas fill-up question?
I had a different issue on gas fill up ...NO CAP ??
SO I call the dealer like a dummy , and complain theres a piece of green duct tape over the filler.. He said remove the tape and read " No cap system"
SO if no cap needed why the duc tape over the filler ? Said in case rain gets in....
But I was assured no rain would get in , or water from a car wash.
Also the manual talks about this special anti tamper gas neck ...Also mentions a special filler funnel specifically for the car and its not in the car , dealer never heard or seen one in an 11 Stang?
Also another surprise was NO JACK .. They said "use your roadside assistance" hmmm
Road help is great when you have time to kill , but what ever happened to get out change the tire .
Also dealer said there is no room in the trunk for either a spare or a jack .
Go figure . I see a trunk big enough for my amp guitars , duffels , tools bag , bottle jack ,ect ect
These necessary items that are missing should be standard. A doughnut spare OK ...
But a pump and bottle of goo - to get you thru your trip at 400AM in no mans land ?
Myself am going to carry a full size spare and tire , change it when the time comes and then drive like my spare is a "pump w/h bottle of goo"
comments pls.
comments pls.
comments pls.
comments pls.
If you keep driving your mustang on empty after your low gasoline light comes on
you are building up condensation in your gasoline tank which is indeed water droplets.
Also doing this you can burnout and ruin your fuel pump and suck the deposits from the
bottom of your gasoline tank into your filter fuel clogging it up.
I drive my mustang right before the gasoline tank go's to empty and then I fill up with
Chevron or Texaco gasoline.I would change my fuel filter every two years or 20K miles
whatever comes first that's what I do.
I purchased my fuel line disconnect tool from my local Ford dealership parts
department and I purchased my Ford Motorcraft fuel filter from my local
Ford delaership parts department also.
Definitley change your fuel filter asap if you haven't replaced it because a
clogged fuel filter will rob you of performance and fuel MPG.
Make sure you use a Ford Motorcraft fuel filter also they are the best
design for our Ford Mustangs.Using quality "top tier" name brand gasoline
from gasoline stations like Chevron or Texaco is always a great idea too.
You don't need the tool to disconnect the fuel lines from the filter; just your fingers or maybe pliers.
Letting your tank go to or near empty = asking for trouble. If my kids ran the tank down below 1/4 they'd lose their keys.
Guess I've been pressing my luck.... living on the edge. Don't really have too many car ppl in my life to take the Do's / Don'ts. Although I was aware you shouldn't run your tank down that low... laziness
I did mine easily w/o the tool. The biggest PITA was removing the plastic shroud.
Part of my personal opinion on not letting the tank get too low has to do with son #2 calling at 3 am one night, out of gas about 4 miles from home. He walked in the rain. Lesson learned. But in addition to the parenting lesson on the pitfalls of getting that low, there's the issue regarding condensation in the tank (and don't be fooled; it can happen in the south too), sucking trash off the bottom, lack of fuel pump cooling, yada yada.
Im with the crowd that never grew up -- i will opt to carry the special funnel ,if its so special...
As far as the comment of AZPETE of the GT/CS having spare ,jack wrench and funnel.??
Maybe springing another $$$ for the CS gets you the cheap jack and spare?
Other GT 2011 Owners in CA ,did your 2011 GT have a spare ,jack ,wrench funnel?
if the car is a brembo brake pack it gets no spare or jack, just the goo and pump. its part of the "track pack" weight reduction an dmore becasue i woudl assuem a donut spare wont clear the brembos.
IMHO it's not that big of a deal for most of us to not have a spare. In my entire 37 years i have had 4 flats, all were in the same month on the wife's car when roofers in my neighborhood weren't securing their trash loads. pissed was an understatement. Other than that I watch what is on the road and avoid running over stuff 99% of the time and have never had a flat on my own.
