Rev Matching / Double Clutching
Since synchronizers on modern vehicles are pretty damn good, is there any point to double clutching besides learning how the concept works? I already understand how double clutching reduces the load on the synchronizers and I fully understand how the system works. Besides, I utilize the concept from time to time. But are there any marginal gains of any type if this method is used on a daily basis on regular roads? I wonder if I should utilize this system on a regular basis or down shift the regular old fashioned way. I am looking to get your input as to how you regularly downshift and why? Remember I am only referring to regular road and highway driving and not track driving. Thanks
Double-clutching, no. I was told overall it was better to down-shift so I always have, but not for that. Really just to stop faster with less wear on the brakes as my first real car was a 15yr old hand-me-down ī78 voltswagon rabbit diesel. Just dead stop 1st, or putt in 2nd for a bit.
The other idea was that keeping the engine with a load, is better overall. I might call bunk on that, as itīs then got a load, but might not be pumping as much lubrication. *shrug* Really, hell if I know, I just Nike it, and just do it. Always have, probably always will since Iīve done it this way for so long. |
I see no point in double clutching on a daily basis. If you need to reach a much lower gear quickly, it may help. I grew up when first gears had no synchros and was taught that you double clutch to get first gear before you were dead stopped or if the syncros were out of a gear, then it would help too.
I do it when down shifting, you don't have to double clutch synchronized transmission. If you have a trans with worn synchros double clutching helps to shift without grinding sometimes.
Thanks for the input, I always saw no point in doing this maneuverer besides pretending like I am a race car driver. Since that aint gonna happen any time in this life time or next, I am going to ride it and shift it the way its meant to be. LOL
No need.
Double-clutching (clutch in-and out twice per downshift) is almost unheard of today. Even on the race track there are very few cars that require it. Almost all professional level cars use a sequential tranny. The only cars I'm aware of that you have to double-clutch are some of the older open-wheel formula cars. At the amateur level, production based racing cars mostly use a tranny just like you and I and they don't double clutch (unless dropping two gears in one shift). Now doing a rev-matching heel-toe downshift...well thats a different story. Its an essential skill on the race track and one that you can practice and have fun with on the street.
Originally Posted by wayne613
(Post 7364931)
Double-clutching, no. I was told overall it was better to down-shift so I always have, but not for that. Really just to stop faster with less wear on the brakes.
Originally Posted by 95PreludeSi
(Post 7365636)
Brakes are always cheaper than a clutch.
I rev-match with out issue so far
