ProCharger 2011 Mustang V6 coming soon!
#22
the duratec 37 has a lot of similarities with the duratec 35 which is used in the ecoboost v6. I can't seem to find any information on the rods or pistons though to see if they are cast or forged, I've heard both.
#23
ENGINE V-6
Type 3.7L V-6
Manufacturing location Cleveland, Ohio (USA)
Configuration Aluminum block and aluminum head
Intake manifold Composite shell-welded with internal runner pack
Exhaust manifold Cast iron
Red line 6,850 rpm, hard limit 7,000 rpm
Valve train DOHC, 4 valves per cylinder, twin independent
variable camshaft timing
Pistons Cast aluminum
Connecting rods Forged steel
Ignition Distributor-less with coil-on-plug
Bore x stroke 3.76 x 3.41/95.5 x 86.7 mm
Displacement 227 cu. in./3,731 cc
Compression ratio 10.5:1
Engine control system PCM
Horsepower 305 @ 6,500 rpm
Horsepower per liter 82
Torque 280 ft.-lb. @ 4,250 rpm
Recommended fuel Unleaded 87 octane
Fuel capacity 16 gallons
Fuel delivery Sequential multi-port electronic
Oil capacity 5 quarts with filter
2011 FORD MUSTANG V-6
TECHNICAL SPECIFICATIONS
10-05-2015 07:40 AM
breaking
10-02-2015 01:27 PM
KingRando
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
mungodrums
Suspension
09-24-2015 10:12 PM
