Anyone running 19x11 wheels in rear? Any problems?
Have a 2008 mustang. I'm looking into a 19x9.5 19x11 set. Just want to know if we can run a set like this without problem. Besides the 19x11 in the rear but the 19x9.5 would also be something different. If you guys have any advice or pics on this please let me know. Thanks
Whether it's a 16" or 22" wheel, you're overall tire OD should be kept roughly the same as OE and tire widths are limited by the wheel width.
The front won't be a problem and is not much different than current setups at 9 - 9.5" width. although I'm not sure if 255's would fit up front on that wheel or if you have to go wider, which I wouldn't recommend due to tramlining. The rear could be interesting, especially if you're lowered. Have you checked tire availability in 19" that'll fit an 11" wheel and still come close to the OE OD?
I don't know how they would fit/handle, but you would want like a 315/35R19 tire on those rears. You would probably be going just a bit (1-3 mph depending on speed) slow but if you have a tuner you can recalibrate it.
Also, probably should have 265/45R19 on the front, but once again, I don't know how that would fit/handle.
This link may help you. He's running 18x11s, so you should have a bit more clearance than he does. http://www.s197forum.com/forum/showt...374#post802374
NorthAmericanTuning
11-09-2016 11:44 AM
inyadreems
08-21-2015 09:10 AM
