Fixed my engine tick, easy fix, important info for all
I took it to my local mechanic. His first test was right on the money. He said the spark plugs back out and the ticking is from exhaust leaking through the spark plug threads. Sure enough 2 of them on the drivers side were loose. He said if they are loose long enough and back out far enough the head threads would get ruined. He also said there is a kit to fix it that fixes it about 75% of the time but, not always. So, if you have engine ticking, check to see if your spark plugs are loose!
That seems really odd...
Have you ever tinkered with your spark plugs, like checked them and them put them back in? Maybe you didnt torque them down correctly or you had dirt on the taper seat.
A lot people can't get the things to come out in one piece let alone get them to back out without some force.(4.6L 2-piece spark plug design)
No, I haven't tinkered with them but, I watched the mechanic do this right in front of my eyes. He told me the last plugs he put in my car are not the 2 piece design. Now that I know the problem, I am going to go buy the long neck spark plug socket. I believe I heard him say today it was a 15.
One other thing I hadn't mentioned. When he pulled the coil pack off, it had a lot of brown down around the bottom half of the rubber. He said that is the exhaust that is leaking out around the plug threads.
Sure, it's very possible that this mechanic didn't torque them to spec. The main reason I started this thread was to let others know what could be causing an engine tick and ended up being my engine tick problem.
