Chronic Fuse Blow
#21
yes we have pulled it out 2 or 3 times since we first put the radio in. i checked all the wiring and everything to make sure there were no loose wires... would one of those voltage equalizers (or watever theyr called..) do it?
#22
If it´s not blowing, then you have something wrong with the harness. I´d bet big money at this point that something you wired is wrong, causing this problem.
If you´re referring to voltage regulator, no. That is for the amp turn-on lines, 5v regulator using the 12v input to give the turn-on the proper 5v turn-on to avoid the ¨thump¨. Using the 12v turn on for it won´t cause direct damage, but it can damage the speakers themselves in the long term. I mentioned this in the previous post, except using a resistor to bring it down to 5v, instead of a regulator.
Point me to this ¨guide¨ you used. Unless you´re used to wiring units from 10+ year old cars, most recent ones have can-bus and other issues you have to work around when wiring an after-market unit in.
#26
He doesn't touch my exterior - yet - and all look mods he does are pre approved by me. Like the front and rear bumper covers we're getting this summer.
Front bumper (can't decide which 1 - I'll let you guys pick it - and neither is not an option)
Rear bumper
Which front one you like best?
Rear bumper
Btw, amazon really isn't the best, or any, place to buy performance upgrades *should have learned that one already*.
#29
jwog666
12-27-2021 08:09 PM
bradleyb
11-27-2015 07:50 PM
