11 GT Fueling System/Transmission Issues!
#21
Mine does grind between 1-2 and 2-3, worse when cold it seems. Its also had a "clunk" sound thats random in all gears.
Just like many others, my dealer told me to wait until properly broken in...at the time i had about 1500 miles. Now im at 7k and ill be taking it in again soon.
Im going to try a fluid change after reading this.
#22
#24
regarding the fuel tank issue:
Have you tried the work around we used to do with the 2005's? Twist the nozzle around from its normal 6 o'clock position and try it at the 1 o'clock position.
The new nozzles at many stations were part of the problem. I guess they don't have smog issues in Michigan...
#26
A clunk sound is normal from time to time but a transmission should NEVER grind! Fluid will not fix that, it needs to be looked at asap! Just a heads up
#27
Thanks for the advice!
#30
I had the fuel issue on my 06 all the time (that really $*%@&$ me off) but I have had zero fueling issues on my 10 unless you count the cost of gas.
