Fender Badges
Thanks 07stang. I know that some mustangs came from the factory wtih no fender badges. Im pretty sure my car is the most basic model you could get in 06, i could be wrong so im assuming.i was going to go with No badges, jsut be cause i didnt want to spend money on fender ones. But now that i was able to buythe package deal if theres no pin holes im not sure if i will use them or no but if there is pin holes then i will definitly use them.
I jsut got to wait and see whats under the GT badges first and hope the previous ower didnt **** up the paint of anytihng
The basic non pony with no rear sway bar has no holes
for Pony Package or Gt fender emblems.
The PonyPackage with the 18mm rear sway bar has
'alignment holes' for the alignment pins on the back
of the PP and GT fender emblems.
If the previous owner whom installed the GT badges
cut the alignment pins off the back of the GT emblems
to get them on the fenders, you will also have to cut
these alignment pins off flush as well.
I did the emblems and used a fixture to align them correctly.
They are 'bent' to fit the curve of the fender.
Do not try and make them perfectly flat.
http://www.cherod.com/mustang/HowTo/FenderEmblem.htm
11-10-2015 11:39 AM
