9psi was recommended from procharger, could i go higher without any worries?
I'm running the 2.87 pulley (13psi) on my vortech... Its around 12.4 psi at the manifold... You can run up to 12 or so and will be good to go with a good tune, I just wouldn't push it too far passed that!
Justin @VMP run 13psi on his wife sixxer in daily driver mode.
16psi @ the track (398 rwhp).
It also helps that the 4.0 has better internals than the 4.6.
first thank you for serving our country if you trust the people doing your work for you listen well ask as manny questions as you can good luck with your build
