How bad is this? Should I replace immediately?
Well I was fixing the exhaust rattle I was having, so I figured while I had the wrenches out I might as well go over the whole car and make sure everything was tightened up. I was tightening one of the bolts to the stock caster/camber plates and one of them broke!!! Should I be really worried and replace immediately?? Or can a shop just fix it by taking it apart and putting a new bolt in?
Idk how the fvk it happened I didnt seem to be tightening it that much and it just popped.... Should I get aftermarket plates? or just see if a shop can replace that bolt??
Are you talking about one of the 3 studs of your damper strut that goes through the shock tower??
Or is it one of the 2 big bolts that secure your strut to the spindle?
The factory doesn't use plates...
Edit: 4 studs you dumb ***!
Also most bolts and nuts have a torque spec.
Heres a pic to show you what I am talking about. Looked at ford replacement parts and the mount itself is only $48. Is this my best option? Or will I be good for a few weeks than just put Ford Racing K springs, and caster/camber plates?
