Cams and Supercharger
It's been awhile since I read up on forced induction and cam profiles that work with them. But if I am remembering correctly, such a cam is cut with high opening and closing rates with little LSA. The LSA is not needed because you are not relying on the air's mass to move it ( which NA relies on). The boost pressure does the work for moving the air.
I also think that the cam lobes are not as fat and do not stay open as wrong. They might have shorter durations.
As I said, it's been a long time since I read up on all this so someone correct me where I am wrong.
Hi,
i write from germany and my english is very bad because its a long time ago when i was at school and learn it. i have a question and i hope anybody can help me because in germany we dont have a good blog for mustang drivers.
i have installed the FRPP Hot Rod Cams and now i install the Rouch M90 Supercharger. The mechanic from roush tell me all another tunes on my pcm going lost when he calibrate it for the M90. what happens when i have the m90 tune but no tune for the cams? motor damage? some drive problems? or give it a tune witch i can have for booth of this parts?
thans for answer
thans for answer
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
