Saleen SC Dyno numbers are in!
Location: Camp Lejeune, North Carolina and Fort Lauderdale, Florida
Well, I'm not quite where I want to be yet...these cams are REALLy causing me a headache!
I put down 402whp and 396 ft lbs tq. The car was running REALLY rich...A/F was around 10.5 up to 4000rpms and then went up to 11.2. The boost stayed around 2.5-3.5 psi until 5000rpms where it steadily rose to 6.5psi from 5000-5700rpms.
Keep in mind, I do have the 3.4 pulley on with the KB BAP, so these numbers are very low...more like 4" pulley numbers.
Seriously considering the Detroit Rocker FI cams now...
Lets get a poll going:
Should I swap the cams and run the pulleys I got and make more boost (about $1100...I might recover $500 or so for my Hot Rods)
Or should I just up the pulleys to the 11-14 psi pulley and hope to get around 7-9psi with teh Hot Rod cams that I have now??
i would say swap the cams to something that is designed to run with a SC. im having brenspeed do a saleen install in mine when i get back from Gitmo, but i still have my stock cams. they told me with the stock cams on my 2010 i will be putting down around 440-450 whp (stage 3 kit, headers, throttle body, axleback). i can imagine that with cams DESIGNED for a SC the gains would be astronomical compared to just changing the pulley. pulley is a LOT cheaper than getting cams though so in the end it comes out to what you want to spend. either way though you will still have a BEAST of a car. just my $0.02
My suggestions:
FRPP Throttle body
AFCO HE
Bigger resevoir for the HE
Custom tuning by someone who knows what the F they are doing.
If you have the Saleen, 3.4 pulley, GT500 pumps or a BAP, you should be making way more power.
Send a PM to Sactown. He has a nice set up.
