this is .....ridiculous
So i isolated the dreaded water leak to the passenger side window weatherstrip retainer TSB 8-26-7, after pulling off right my fender and replacing all my cowl grommets with new ones. Ordered the part through ford, and it stopped the leak for about three weeks. Now its back in the same location. Somehow that brand new seal with the whole new plastic retainer is still failing to seal the water from entering the holes in the a pillar. I tried reseating it - that failed to fix it. My car has no warranty. After i spent weeks of taking out all the interior and carpet to dry everything and clean it, after heavy downpour tonight i have tons of water in the car once again. I am really tempted to say screw it and let it rot, I have invested too much time and money in this for the car to still leak. I am out of ideas, besides to shoot some foam down the holes in the a pillar.
Please, I need help.....I have no clue on what to do.
Ahh, I had that infamous water leak. It was at the dealer for 10 times with over 30 days. They could never solve it. Finally, an engineer from Ford came out and they saw that the body wasn't properly sealed by the robot, guess it wasn't calibrated, so it left a hole.
Just saying it could be one of the causes, but that's the problem I had.
That was the first area i checked and it always remained clean, and my cabin air filter looks perfectly fine and is dry as a desert. The water is definitely entering from above the junction box. Once i removed the junction box, the top of the metal bracket that it attaches to is wet.
From what I understand, the right-most cowl grommet (ie furthest to the passenger side) drains into an area that lets water get behind the SJB, even though the other cowl grommets drain into the cowl channel.
A friend and I will be attempting this repair on our cars tomorrow so I'll be sure to post up with the results.
One other leak location which isn't a SJB wetter are the lower drain plugs, accessible and visible on the firewall below and just beyond the battery. These can clog and allow water to drain into the passenger compartment thru the cabin air filter. When you had the cowling off to do the TSB repair, you may have noticed debris in the bottom of the well if you were looking for it.
Hi F0RD4LifE,
I can understand how frustrating that must be! Have you determined the source of the leak yet? If not, you may want to have your local dealer take a look and see what they can find, and you may want to have them search for your gas hand noise as well. If you have any concerns, feel free to let me know if I can help.
ssimaniac,
I am glad your dealer was able to send an engineer to diagnose your leak and resolve your issue!
~Natasha
ssimaniac,
~Natasha
Hi F0RD4LifE,
ssimaniac,
~Natasha
ssimaniac,
~Natasha
