Sponsored by:
Sponsored by:
pulling up the carpet in a 2006 GT
Old 06-12-2011, 11:20 AM
Joe Vtang
Joe Vtang's Avatar
Default pulling up the carpet in a 2006 GT
So my middle son puked in the back seat of my car a couple of days ago. The leather cleaned right up of course but the carpet took a beating. I've shop vac'ed, used my wife's hot water upholstry cleaner and now have a box of baking soda liberally sprinkled on the section but the smell persists.
I'm thinking I need to pull up the carpet but I'm wondering how bad a job it's going to be. Anyone ever do this and have things go back together right?
Any other suggestions before I go that route?
Joe Vtang is offline
Old 06-12-2011, 01:05 PM
Shadow7874
Shadow7874's Avatar
Pulling the carpet shouldnt be hard work but it will be time consuming. You will probably need to remove all your seats, the center console, and a bit of the trim before the carpet itself can be removed.
If you do go that route make sure your battery is disconnected before you remove your seat harness and that it stays disconnected until the seats are reconnected or else your airbag lights wil come on and require ford to fix. And if you go to a stupid dealership like mine they will tell you it will cost $1350 to fix it...
If it were me, id order a bit of damplifier pro or dynamat and do some sound deadening while the interior is stripped. Should make for a nicer ride while your already doing most of the work
Shadow7874 is offline
Old 06-12-2011, 07:45 PM
Goldenpony
Goldenpony's Avatar
A couple of products you might try first. Nature's Miracle or Odor Exit. Both of these are very good products for removing organic odors. They are usually sold in pet stores or veterinary offices. Worth a shot.
Goldenpony is offline
Old 06-12-2011, 07:51 PM
javina80
javina80's Avatar
+1 on the Natures miracle... Stuff works great. Also try OxyClean in spray form. Works really well also.
javina80 is offline
Old 06-13-2011, 07:31 AM
Joe Vtang
Joe Vtang's Avatar
Thanks for the replies. Sounds like pulling the carpet is a last resort. The baking soda helped but the smell persists. I'll give those other products a try.
Old 06-13-2011, 03:26 PM
MustangFirstCar
MustangFirstCar's Avatar
That blows dude. Literally! Anyways, it shouldn't be too hard, but if I were doing it I would consider putting some sound deadening material down there. You will definitely have to pull up the seats, and probably some of the trim, so like the others said, be careful with the seats and the airbag lights and all.
MustangFirstCar is offline
Old 06-13-2011, 03:44 PM
Shadow7874
Shadow7874's Avatar
Pulling the seats is maybe a 10 minute job for both the front seats and the back just FYI.
The front seats are attached with 4 bolts each (pretty easy to access them too) and the rear bottom is just a little push tab thing that releases it. The rear backs remove with 1-3 bolts (might get by with only removing the one center one)
Definitely try a few other products if they are cheap but just know that if it comes down to pulling out the carpet it shouldnt be a terrible task at all.
Old 06-13-2011, 04:09 PM
07 Cervini
07 Cervini's Avatar
The only thing I can help you with is with some comic relief:
I think Jerry ended up selling the car because the smell wouldn't go away.
07 Cervini is offline
kevsgt
10-09-2015 10:12 PM
b8checker
10-08-2015 12:55 PM
jrrhd73must
10-02-2015 09:17 PM
BeatnikFink
10-01-2015 08:00 PM
b8checker
09-30-2015 07:11 AM
Quick Reply: pulling up the carpet in a 2006 GT
