Sponsored by:
Sponsored by:
Wheel vibration
Old 06-22-2011, 12:01 PM
BlueBellThunder
BlueBellThunder's Avatar
Default Wheel vibration
My 2010 Mustang Gt has the wheel vibration. In Sept 2010 I had the tires road force balanced and it went away, however about a month ago the vibration came back, but not as bad, very minor but annoying on a car with 13000 miles. I took it to the dealer a few weeks ago to remove the rotor clips but still the same. Another dealer told me that the tires they put un the mustangs suffer from flatspotting. From what I've read about flatspotting is that it only lasts a few miles until the tires warm up. My commute is 20 miles one way, and the vibration doesn't go away. Any suggestions to tell the dealer next time I go in for service. Thanks.
BlueBellThunder is offline
Old 06-22-2011, 02:38 PM
Nuke
Nuke's Avatar
If the RoadForce balance isn't detecting the problem then I question the wheels and tires. I know that quite a few 05 thru 10's have vibration issues beyond the wheels, tires and rotor clips that seems to have never been solved. Even my '07, with the RoadForce balance, isn't as silky smooth as I would hope for. My guess at this point is something in the drivetrain that is simply a chronic design issue that Ford won't admit to.
Flat spotting should dissipate after about 5-10 miles of driving or less as the tire compound warms up and the tire rounds out. Any remaining flat spot is a defect that the RoadForce balance would certainly pick-up.
Nuke is offline
Old 06-23-2011, 12:09 PM
157dB
Cut & Paste Expert
157dB's Avatar
How does the dot on the tire correlate to
the weights installed?
Got them lug nuts torqued to 100 Ft Lbs
or just the air gun torquing technique?
THIS is what the DEALER should have tested for....
157dB is offline
Old 06-24-2011, 08:43 AM
BlueBellThunder
Thanks for the advice. Next time I go for service I'll ask them to do what you suggested and hope for the best. The shaking in the steering wheel is very minor, more just a little bit annoying, but before I had the road force balance the car felt unsafe to drive on the highway.
Old 09-03-2014, 05:13 PM
BlueBellThunder
Default Long overdue update
I just bought new tires for my car last week, Cooper Zeon 18" all season. Before I got them the steering wheel shake came back, not to bad but noticeable. When I got the new tires it did improve the shaking a lot but it's sometimes there sometimes not. I only notice it at speeds above 60 and with my current commute I usually cant go past 55. To many money hungry cops in the towns I drive through. Tomorrow I'm going on a week long road trip so I cant have the car looked at until I get home. The shaking is very minor, I can only see it if I let go of the steering wheel, and when I let go it tracks perfectly strait. Today running some errands my driving was mixed highway and city. On one road I got up to about 75, smooth as silk. Then on other roads driving as slow as 55 if I took my hands off the wheel I would notice the shake, it is a very miniscule shake but it is bugging me. The car has 31000 miles on it, so I hope it doesn't need an expensive repair. There is no warranty on the car since it is 5 years old. When I first encountered this issue a couple of years ago the shaking was pretty bad until I had the road force balance, the current shaking is nowhere near as bad, so I have complete confidence taking it on a 2500 mile road trip.
Thanks in advance for all your advice.
Old 09-03-2014, 07:02 PM
PNYXPRESS
PNYXPRESS's Avatar
I believe the shaking is normal. My 2008. Does it too. It might just be the road isn't smooth and the car is just giving you feedback.
PNYXPRESS is offline
Old 09-03-2014, 08:19 PM
BlueBellThunder
You're actually the first person who has said its normal. I also think it might be, because when I first had the shake it was very noticeable. Before I replaced my tires it was bad, now it's either very mild shaking or none at all. I read somewhere that tires need to be broken in for a couple of hundred miles, although I'm not sure I believe that. I've driven less than 100 miles on the new tires so far. I'll definitely know tomorrow, I'll be driving from NJ to Chicago.
I'll post an update tomorrow night when I get to my hotel.
Old 09-03-2014, 10:01 PM
Rudolph Hucker
Rudolph Hucker's Avatar
tyre flat spotting takes longer to go away than u think..mine can take 1 hour
get your toe checked
uneven road can do it..
i rekon even motor vibration has something to do with it aswell..
Rudolph Hucker is offline
Old 09-04-2014, 07:51 AM
05 Mustang
05 Mustang's Avatar
Does it do it even when the rims/tires are rotated front to rear?
05 Mustang is offline
Old 09-04-2014, 08:02 AM
jsimmonstx
jsimmonstx's Avatar
Have your toe checked. DO NOT do it at a Ford dealer. Go to Firestone or Goodyear. I paid fort the Firestone lifetime alignment two years ago, and have been back twice for toe adjustment (because of mods I performed). I didn't pay anything for alignment services since the initial payment (I think it was $169 or something like that).
jsimmonstx is offline
Quick Reply: Wheel vibration
