L/T install stuck on steering coloumn NEED HELP ASAP!
so im doing the steering coloumn and the shaft is sliding after i loosened the bolts, but i need it to slide about an a 1/2 inch more and i cant get it to do that. i read to unbold the rack and pinion but i dont know what that is, Please help pic would be nice so i know what your talking about thanks
When I did my LT install my father and I ran into the same problem. He said normally it would just slide out but like you said it just needs to slide a little bit more to pop out. We ended up just unbolting the 2 bolts that hold the rack in place and it made it 10x easier. Only thing is you will most likely need an alignment after
Turn the steering wheel a 1/4 turn to the left and bungee cord the wheel to the shifter or brake. This will allow straight access the upper steering shaft bolt. Remove it, and also remove the lower bolt that goes in the the lower steering knuckle. Both bolts must be completely removed. MARK BOTH ENDS with a sharpie so you get it back in correctly
Next go inside the car and unbolt the 2 10 mm (I think) bolts that are holdint the steering column coupler inside (looks like a saddle) to the firewall. once you take those nuts off you can pull the top of the steering column in towards the cabin from inside. With the steering wheel locked in place everything will go back the same way you took it out. This will release the upper knuckle. THen you can pull the steering shaft out clean for good clearance on the LT's.
Stay AWAY from trying to unbolt the steering rack.. not necessary with the above process.
Good luck!!! LT's are not technically difficult, but quite the PITA
PM me if you want some great instructions from another site.
