SS Mustang: Oil Catch Can Rubber Cap...
The little rubber thingy is pushed off by blow-by air out of the closed valve...does that make any sense, if anything there should be a vacuum if the valve was leaking?
Is the valve leaking? If it was, you would notice oil dripping out of it.
If it is not, then any blow-bythat might be occurring wouldn't push the rubber "nipple" off. Perhaps it's just the heat in the engine compartment heating up the air in the drain tube, causing it to expand and push the rubber plug off? Just a thought.
